Cable sticking (Solved)
13 May 2015 08:25 - 20 May 2015 13:50 #4450 by AJ WH Ranger
Cable sticking (Solved) was created by AJ WH Ranger
Hey guys I need some advice. Last night I was cutting the grass at my new neighbors house and shut off the tractor to say Hi. When I got back to the tractor to start it back up both my choke and throttle cables were frozen.?
What can cause this?
How can it be fixed?
So I was able to free up the throttle cable but the choke was still stuck. The tractor ran for about 45 minutes after that then it just died, to never start again.
Im thinking the choke may have been on for that amount of time and possible fouled out the plug or something.
I need your expertise. Please Help.. :hiding
Last edit: 20 May 2015 13:50 by AJ WH Ranger.
13 May 2015 08:50 #4452 by nappypappy
Replied by nappypappy on topic Cable sticking
AJ WH Ranger wrote: Hey guys I need some advice. Last night I was cutting the grass at my new neighbors house and shut off the tractor to say Hi. When I got back to the tractor to start it back up both my choke and throttle cables were frozen.?
If the choke is stuck on my 416-8 it wont run 5 minutes....I no that's not any help for you :2cents
13 May 2015 09:18 #4453 by Geno
Replied by Geno on topic Cable sticking
Sounds like a good place to start AJ. That's a pretty weird scenario.
13 May 2015 11:13 #4455 by GT 14
Replied by GT 14 on topic Cable sticking
I would take a look at the carb, something is out of position or broken.
13 May 2015 14:56 #4459 by M Bailey
Replied by M Bailey on topic Cable sticking
AJ are the cable sheaths plastic or wound wire? If plastic the engine heat could have deformed and melted them. If they are wound wire I'd look for a physical problem such as something kinked. It's unusual for both cables to freeze while in operation. Pics would help and good luck.
20 May 2015 13:48 #4736 by AJ WH Ranger
Replied by AJ WH Ranger on topic Cable sticking
First, Thanks everyone for pitching in with suggestions.
Here is an Update.
I found the problem(s)
First one, both of the cables were seized up :waiting weird I know. A WD-40 bath and some coaxing did the trick for those.
Second one, this is the one that bothers me the most and took the longest to figure out. I would imagine it would take anyone a few minutes to troubleshoot their way to this but, the kill switch I had wired up had apparently broke internally therefore shorting it out to ground regardless of switch position. :beat (swear words)
So now I am back to mowing with the 1968 Lawn Ranger with no hood so I have a way to short the plug to ground so I can shut it down. :rolling3
20 May 2015 13:52 #4737 by M Bailey
Replied by M Bailey on topic Cable sticking (Solved)
Glad you got her going AJ, you done good. :goodjob
20 May 2015 14:05 #4739 by nappypappy
Replied by nappypappy on topic Cable sticking (Solved)
:goodjob
20 May 2015 19:57 #4744 by Geno
Replied by Geno on topic Cable sticking (Solved)
Glad you found it AJ. So it looks like 3 things went pretty much at once? Doesn't get much weirder than that. :whew
20 May 2015 20:40 #4746 by Trouty56
Replied by Trouty56 on topic Cable sticking (Solved)
Geno wrote: Glad you found it AJ. So it looks like 3 things went pretty much at once? Doesn't get much weirder than that. :whew
That is weird.....sounds like something that would happen to me......
