416-h fuse block
  • A.Wend1
  • Member
  • Member
27 May 2025 16:26 #18575 by A.Wend1
416-h fuse block was created by A.Wend1
I need some guidance please. I have your pigtail fuse block Geno and am trying to make sure I wire it up correctly to a 416. I do have a wiring diagram for the tractor and see what colors I have and where they go. However with the new fuse block not having a bus bar I need to put the hot wire to two wires on the fuse block. However do I then also put in a fourth wire? That wire would be the wire coming out of the factory block? So it would be two wires from the new block to a hot wire. Then the other wire coming out and continuing on would go there as well? Making four wires?  I have attached a picture of the back side of my factory block. Thank you.
28 May 2025 08:34 #18576 by Geno
Replied by Geno on topic 416-h fuse block
There's an old tutorial here -  WHS Fuse Block Install
  • A.Wend1
  • Member
  • Member
29 May 2025 23:31 #18578 by A.Wend1
Replied by A.Wend1 on topic 416-h fuse block
Thank you sir. It was as I thought the four wires do all go together and then the others go to the same spot. Thank you.
