48" Mower Deck Redo
- 23 AUTOMATIC LSE
30 Apr 2020 03:57 - 30 Apr 2020 04:12 #15917
by 23 AUTOMATIC LSE
48" Mower Deck Redo was created by 23 AUTOMATIC LSE
Decided to have a go at redoing my belly mower deck for the D-200. Purchased a complete working deck, but with a not so good shell, in a job lot of tractors and parts, along with a good shell. The complete deck was bent up a bit and had rusted through. So I started with redoing the support above the good deck. Wire brushed it and then sanded it on both sides. Then I sprayed on a coat of primer. Somewhere along I noticed that there was 2 of the spot welded nuts missing. So I go out and took a look at the support on the complete deck. Yep, it had all the nuts still on, but; the spindles have to be removed along with the idler support bar. No problem except one of the spindles had the nut welded on, and another had a broken housing. Oh well got out the grinder and cut the nut off. Ruined the shaft, but the good shell had one spindle still on, with a good shaft. So round two, redone the wire brushing and sanding, then sprayed two coats of primer on it. Also refinished the idler support bar and the quadrant. The job lot of parts also came with a good gauge wheel support and the two good carriage draft bars.
Last edit: 30 Apr 2020 04:12 by 23 AUTOMATIC LSE.
- 23 AUTOMATIC LSE
30 Apr 2020 10:07 #15920
by 23 AUTOMATIC LSE
Replied by 23 AUTOMATIC LSE on topic 48" Mower Deck Redo
Rust hole
- 23 AUTOMATIC LSE
30 Apr 2020 10:20 #15921
by 23 AUTOMATIC LSE
Quadrant and idler pulley tensioner bar
- 23 AUTOMATIC LSE
30 Apr 2020 10:46 #15922
by 23 AUTOMATIC LSE
Over deck support
- 23 AUTOMATIC LSE
30 Apr 2020 13:35 #15923
by 23 AUTOMATIC LSE
Pivot bracket backing plates
- 23 AUTOMATIC LSE
30 Apr 2020 15:16 #15924
by 23 AUTOMATIC LSE
Pivot brackets
30 Apr 2020 20:07 #15928
Replied by Geno on topic 48" Mower Deck Redo
Very nice work Mark.
It takes more work than most people know to restore a deck.
- 23 AUTOMATIC LSE
03 May 2020 01:22 #15940
by 23 AUTOMATIC LSE
Pics that should have appeared in previous reply.
- 23 AUTOMATIC LSE
03 May 2020 01:32 - 03 May 2020 01:35 #15941
by 23 AUTOMATIC LSE
I have this redo almost complete, however this will be the last that I reply to the post as I have unsuccessfully attempted to add replies w/ pics but they fail to show up. It is much more of a complicated procedure to submit a thread w/ images on this forum than any other forum that I have used. Maybe it's just me, but if you want to view the redo you can P.M. me and I will refer you to the other sites that it is posted on. Sorry. P.S. Geno if you want to delete this thread feel free.
Last edit: 03 May 2020 01:35 by 23 AUTOMATIC LSE.
03 May 2020 08:36 #15942
This the easiest forum on the planet to add pics too, take it from someone who has 4684 posts here and added over 30,000, and they all work lol. I took the time to send you an email reply yesterday as to what the problems may be, but the forum is not the problem...
Here's a 4 year old post in the help section, if there is anything easier to do than drag and drop anywhere in the world I would sure love to see it. How to add a pic to a post
