Wheel Horse Tiller Pulley Puller
01 Nov 2025 17:34 #18745 by Geno
Wheel Horse Tiller Pulley Puller was created by Geno
I had this posted then messed with it and it got lost, my bad this time...
This is the repost so peeps can see how to make one like ours if need be.  The pics are pretty self explanatory.  The square tubing is 3/4" x 1/8".  It was made with the tiller on the bench to get everything else right.  If you want to build one like this and need more measurements or info just give me a call.
01 Nov 2025 17:39 #18746 by Geno
Replied by Geno on topic Wheel Horse Tiller Pulley Puller
On the attempt to use it the first time it started to bend the square tubing so angle iron was added to the back side so it could still be slid over the shaft.  The front piece got another piece of square tubing added inside the other two.  It was still a hard pull and was popping and barely moving like steering wheels do in a press but it did come off.  I doubt there are many this tough to get off.  I've done a lot of them and never had need to make a puller until now.
I added several pics of views from different angles to see the finished product.
Time to create page: 0.148 seconds
