Welding Table Hoist for Lifitng
11 Oct 2025 11:48 - 11 Oct 2025 11:48 #18714
Welding Table Hoist for Lifitng was created by Geno
This is a truck hoist but I'm putting it on the big welding table.
A few weeks ago I lifted 7 transmissions, a Kohler starter generator engine, and some other things to put on a pallet and put outside to make room for the work on Tim's tractor I just finished and some other big jobs coming in. Needless to say my back wasn't very happy about it. A few days later I lifted Tim's 12 HP Kohler engine and put it on the bench and that did it in. The chiropractor has me straightened back out but there was some real pain I haven't felt for many years that lasted about a week. Realizing I wasn't superman anymore it was time to do something about it...
I ordered this and it arrived 3 days ago. I started playing with it in spare time and seeing Tim's is done and getting picked up on Monday I'm going to try to wrap it up on Mon. This will be a real back saver and make things a lot easier considering I'm the only one around here most of the time. I still exercise every day but I do tend to overdo things at times...
The best place to put it out of the way was on the front corner of the table where the mag vise was. The lift does 1,100 lbs which is more than I need. The bench will hold it just fine. The bench top is 2 sheets of 5' x 10' x 1/2" steel that weigh 1092 lbs each (2,184 total) let alone all the I beams and metal under the top. The entire table weighs over 4,000 lbs. I'll put a pic of the specs of it in the last pic, it's really versatile and has a really long reach at 220 lbs that will take care of Kohler engines and Wheel Horse rearends without a problem.
These pics are the start of things, more to follow later.
Last edit: 11 Oct 2025 11:48 by Geno.
11 Oct 2025 18:24 #18715
Replied by Geno on topic Welding Table Hoist for Lifitng
Holes are drilled, mess is cleaned up, and lift is mounted. It folds down to save space but it's almost 7' off the floor so I'll prob just leave it pointed toward the press and lathe when not in use. It came with a wired controller but it won't be used, it's getting a separate relay and wireless remotes put on it so I can be near the work piece when using it. This is really important when putting a restored motor on a restored frame. That's what was the last straw for my back doing it by hand when it went out...
I really like the decal in the last pic, gave me some ideas...
15 Oct 2025 18:51 - 15 Oct 2025 18:55 #18718
I thought today would be quiet, nope.
I bought an outboard battery box on Amazon for $12 and everything went inside it. It had a divider in it for multiple size batteries but I used the divider to mount the circuit breaker, winch relay, and wireless control box in. I can disconnect the plug at the top near the winch then charge the battery on the bench, or put the box somewhere out of the way until needed. It would also make it easy to disassemble the crane if need be.
These pics show the parts, box, divider, the layout, and beginning of the project.
Last edit: 15 Oct 2025 18:55 by Geno.
16 Oct 2025 18:46 #18719
It's all finished up and working. One of the best things ever added to the shop says my back...
The first 3 pics show how the electronics come out if they need something. Unhook the battery, 2 wires for the volt gauge, the winch plug, and it comes right out.
23 Oct 2025 18:46 #18728
Just a few more small things done to it lately. The pulley made on the hoist cable was cut off and a link with a heavier swivel hook put on. Now the hook can be changed if ever needed without having to cut something off.
I also thought it wouldn't be right to not have some Wheel Horse stuff on it... The locking knob was changed to a Wheel Horse shifter knob, the end of a PTO grip was cut off to fit under it, and a Wheel Horse lift handle grip fit the swivel handle perfect.
All it really needs now is the orange pieces painted red...
