18 Automatic Tool Box
25 Mar 2016 08:05 #10947
I would put both pieces below and fasten by welding in the screw holes so there are no bolts showing, but that won't be the best for water proofing. I can't see you letter it get wet either though.
25 Mar 2016 16:50 #10951
Replied by nappypappy on topic 18 Automatic Tool Box
That's some nice work in my book................:smile2
- 23 AUTOMATIC LSE
25 Mar 2016 21:09 #10952
by 23 AUTOMATIC LSE
Thanks, I had a go at disassembling the hinges, in order to find out if I could get the cosmetic parts plated. This was a success in part, as I ruined a couple pieces. I have more on order, with the intent of a more careful and knowledgeable disassembly, this time. I am leaning on the "Both halves above" method as a necessity in order to make the water-proof endeavour more of a simpler approach. Current plan is to cut a piece of flat rubber {with adhesive backing} to surround the toolbox top perimeter area. This should act as a seal against the underside of the cover, when closed. P.S. I have taken the cover to the... are you ready for this? ...chrome plating shop! Yep, chrome cover and hinges, but at a cost 6-8 weeks out till complete. Oh well, I'm sure I will find something else to do in the mean time.
29 Mar 2016 05:39 #10964
Bling is right!! How is the tractor coming along??? Did post any pics of it yet here??
- 23 AUTOMATIC LSE
29 Mar 2016 07:01 #10965
by 23 AUTOMATIC LSE
Thanks Trouty, no I have no I posted any more pics yet. The tractor isn't coming along very fast, I have just received word from the gentleman doing the custom extended axles, they are done except for the hardening; however, I am not quite progressed far enough along to be able to assemble them when I receive them as I am still working on "page #2" of my Assembly Order List {the tie-rods and drag link and tie-rod ends.
P.S. maybe I will post a sneak peak picture later, if I cam.
- 23 AUTOMATIC LSE
29 Mar 2016 07:48 #10967
by 23 AUTOMATIC LSE
Here are a couple of pictures of the tie rods, drag link and tie rod ends. More bling I suppose!
29 Mar 2016 08:19 #10969
purr-dee......................:smile2
30 Mar 2016 05:21 #10978
Patience is another attribute you possess Mark!! I love what you are doing......
