What's everybody doing?
20 Nov 2026 17:34 #19223
Most of this week was in the 70's until this Sunday so I switched gears again. Gotta take advantage of all of this warm weather showing up this month.
The Cobalt finished getting detailed today and put in the smaller garage and covered up for the Winter. There's still plenty of room to walk around it and room to get dozer blades out so it worked out really good. The CTS will get detailed and covered up as well and the Winter ride will be the Escalade as usual. The Kubota will spend the Winter in the shop. It will get a little work, maintenance, a good cleanup, and a few mods I've wanted to do to it for a long time then it will get covered up as well. It already has the new Kubota quick attach top cover on it which was one thing I've wanted for a long time. It being in the shop takes up a lot less room and gave me even more floor space.
The tractors were rearranged under the center rack and 2 of the 520-8's put together under there. The center isle right side of the center rack that used to be cluttered up is all cleared out and there's lots of room there now. The 753 is coming out tomorrow and getting torn down and put on a rolling shelf tomorrow. It will be restored and turned into a tricycle that will be a twin to the one done for Bethie Pond this Winter as time allows. After it's done it will go up front with the other ones.
21 Nov 2026 17:11 - 21 Nov 2026 17:15 #19224
Got some more things crossed off the list while it was another warm sunny day.
We also had time to get the 753 torn down I mentioned yesterday to restore it. Some of it was already apart so it wasn't too bad. It's a super nice tractor with nothing more than some surface rust so it will be a super nice one when done. There's still a few things that still need to come apart but it's mostly done. It's on a rolling shelf and I can work on it in spare time this Fall/Winter. I'll start a post on it in the Resto Section when I get started on it.
I'll be out of the shop some of next week to get some other things done but will be in the shop some too.
Last edit: 21 Nov 2026 17:15 by Geno.
23 Nov 2026 17:19 #19225
Went to the Chiro peeps, filled propane tanks, ran errands, then started piddling with little things in the shop I've been meaning to do for awhile. Started a good cleaning on the work bench and got a newer style 8 speed tower ready to weld back together tomorrow that I took apart years ago to press the lift arm off of the shaft. I always break 1 end loose so it can be fitted back together to get it right like in the pic below. It makes things a lot easier to do it that way.
24 Nov 2026 17:10 #19226
Got the newer 8 speed tower welded up this morning and put on the new shelves with the others. It has a lot more spot welds than it did so it should be good.
Got back to finishing more of the 753 tear down. I'll prob start a post on it in the Restoration section soon to keep up with it easier although posts may be spaced out being a spare time project. The nice original choke cable came out easy but the throttle cable was a pain. They have the nicest factory lettering on them I've seen so they were worth it.
The steering wheel had to be pressed off with the roll pin still in it to get it apart, it happens sometimes. The shaft did need some work in the lathe after doing it that way but the main thing is the parts are saved.
The frame was scraped down and it's super nice. No rust pits on the frame (even the transmission side), battery box or front rod. This is gonna make a super nice tractor when done.
Time to create page: 0.157 seconds
