sharping blades
Or when is it time to replace them or how many times can they be sharpened?
You can take 25-30% of the width for sure but if the metal is worn thin from abrasion get a new one.
If you just put an edge on you can sharpen 50X.
Too rusty bent or twisted, get new ones.
And you should check the balance, just put a nail in the wall and hang the blade from the spindle hole.
ok thanks.....belt sander sounds like a good idea.........I was thinking about taking my blades some place to be sharped but might just try and do it myself.GT 14 wrote: I take mine off the deck and sharpen on a belt sander (makes a nice edge). You don't need to take all the nicks out just put an edge on. (10x blade life)
JustinW.73 wrote: I just use a 6 inch bench grinder. I would think the sandpaper would wear out fast.
Sand paper holds up very well, blade metal is fairly soft.
ok thanks and i will check for cracks....M Bailey wrote: Pappy I agree with GT's method, I also use a belt sander to sharpen blades. When you pull the blades make sure to check them for cracks around the retaining bolt.
- dcrage
- Member
