Project Clydesdale
- Kurt-NEPA
12 May 2019 05:54 #15447
I agree Nappy. It looks really nice.
Fantastic job Geno!
Fantastic job Geno!
12 May 2019 08:42 #15448
Go big or go home.
:rolling4
Geno wrote: Are you saying that should be the next project?
Go big or go home.
13 May 2019 10:14 #15449
I went over the hood with some 320 grit on a DA for a dent check and it looks good. Brake rods and hood are painted, I still need to clear coat the hood this week.
13 May 2019 13:15 #15451
Just a little vid of 2 of the strobes working.
13 May 2019 13:18 #15452
Finally moving this out into the public section today. :smile2
14 May 2019 17:37 #15454
The transmission pulley is now a double pulley and I found a belt that will work so now I can move on. The fender is cut pretty close to where it will end up and now it's tensioner time.
15 May 2019 13:33 #15457
Main tensioner is figured out and made the bracket for it this morning. It will swivel on the step mount rod, be adjustable in and out, have a bearing and grease fitting that will be accessible from the top. Other than the custom bracket, like everything else so far all of the other parts are parts used originally by Wheel Horse, the thrust washers, collars, bearing, pulley, and spring.
15 May 2019 19:52 #15458
Main tensioner is all done, very happy with the looks and simplicity of it. The last fender is also fitted to the tractor.
16 May 2019 10:04 #15460
I learned a new trick from my new helper Clint yesterday. I make a lot of cardboard patterns for things, he uses wax paper. The wax paper just gets laid on the part, trace it with a pencil, then you have a quick pattern to cut out with scissors. It can then be transferred it to cardboard to trace out on metal. It saves hours of fitting and whittling on the cardboard lol.
He got the patterns done for all 4 fenders yesterday in no time.
Time to create page: 0.173 seconds
