Working on the '66
09 Apr 2015 11:22 - 09 Apr 2015 11:24 #2915 by AJ WH Ranger
Replied by AJ WH Ranger on topic Working on the '66
Ok next question guys.
So if I know the toro part number for a couple parts I need. How do I go about finding a cutsheet for it so I can find the actual size and get a replacement (not from Toro) ?
Toro Part numbers are:
1303 Seal
1508 Needle Bearing
www.toro.com/en-us/parts/Pages/PartsDeta...ro-parts-lookup-tabs
Last edit: 09 Apr 2015 11:24 by AJ WH Ranger. Reason: Added Link
09 Apr 2015 11:28 #2916 by AJ WH Ranger
Ok got this far.
Old Toro # Description New Toro #
1303 Seal 100441
1508 Needle Bearing 252-6
09 Apr 2015 11:56 - 09 Apr 2015 12:00 #2917 by M Bailey
Replied by M Bailey on topic Working on the '66
AJ the bearing is a Torrington B1212, 1" OD 3/4 ID 3/4 long and the seal an SKF 7410, 1" OD 3/4 ID 1/8 wide. Available on ebay and much cheaper than TORO!
Last edit: 09 Apr 2015 12:00 by M Bailey.
09 Apr 2015 12:08 #2918 by M Bailey
A note of trivia, those numbers 1212 on the Torrington needle denote the ID and length in 1/16 inch increments 12/16 ID by 12/16 length.
The following user(s) said Thank You: GT 14, AJ WH Ranger
09 Apr 2015 12:15 #2920 by AJ WH Ranger
M Bailey wrote: AJ the bearing is a Torrington B1212, 1" OD 3/4 ID 3/4 long and the seal an SKF 7410, 1" OD 3/4 ID 1/8 wide. Available on ebay and much cheaper than TORO!
Awesome Thank You!!!
I would imagine that our maintenance guys should have these in stock here. If so that would be awesome!
09 Apr 2015 14:41 - 09 Apr 2015 14:42 #2934 by AJ WH Ranger
That Torrington Bearing turns out be a Koyo: www.applied.com/apps/commerce/catalog/ca...r=0&type=a&mp=B-1212
And I can't believe that deck needs 4 of them! :doh
Last edit: 09 Apr 2015 14:42 by AJ WH Ranger.
09 Apr 2015 15:28 - 09 Apr 2015 15:29 #2935 by Geno
Replied by Geno on topic Working on the '66
Does the seal cross to a CR7410?
Bearings are here for 5.82 + free ship for Prime Members or at 35.00 order. I keep toting Amazon... LINK :)
Last edit: 09 Apr 2015 15:29 by Geno.
09 Apr 2015 17:23 - 09 Apr 2015 18:24 #2944 by Trouty56
Replied by Trouty56 on topic Working on the '66
for seals....NAPA always cross references to the SKF number but starts with NOS for example...SKF7410 = NOS7410
Chicago Rawhide cross reference site for seals....throw the WH part number and behold the SKF number....at least most of them....
www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
Last edit: 09 Apr 2015 18:24 by Trouty56.
09 Apr 2015 17:28 - 09 Apr 2015 17:29 #2945 by AJ WH Ranger
Geno wrote: Does the seal cross to a CR7410?
:sissy :nono
Thats not the correct bearing mister! the bore dimension is wrong..
But I will forgive you this time and :delete your post to avoid confusion. :yes
This here is the correct one: www.amazon.com/Koyo-B-1212-Complement-Ro...&keywords=Koyo+B1212
Last edit: 09 Apr 2015 17:29 by AJ WH Ranger.
09 Apr 2015 17:31 #2946 by M Bailey
Trouty56 wrote: for seals....NAPA always cross references to the SKF number but starts with NOS for example...SKF7410 = NOS7410
Bob, that's a great resource for sure. :goodpost :thumb1
