Routine Maintenance
11 May 2015 10:53 #4313 by M Bailey
Routine Maintenance was created by M Bailey
Time to service the C-101 today. With 32 hours since last years rebuild on the meter and 25 since the last service it was time to get dirty. Greased the axle, spindles, wheels and steering sector. Checked the trans fluid level and cleaned the air pre-filter and blew out the paper filter. I do not oil the pre-filter as I've found that the oil leeches into the paper filter and shortens its usable life.
Get out the tools for the oil change including the handy little oil trough which makes changing oil with a deck on a snap.
2-1/2 quarts of oil and a new sticker under the hood and the old horse is good for another 25 hours.
Putting the wrench size along with oil capacity on the sticker helps out for next time, especially if you're like me and can't remember what you had for breakfast :rolling3
11 May 2015 12:11 #4316 by Geno
Replied by Geno on topic Routine Maintenance
The handy little oil trough, what an idea! :clap
11 May 2015 12:51 #4321 by GT 14
Replied by GT 14 on topic Routine Maintenance
Good idea Major, always a pain with the deck on.
11 May 2015 16:17 #4336 by M Bailey
Replied by M Bailey on topic Routine Maintenance
I should have posted this earlier, here's what the drain trough looks like in its entirety. Can't remember where it came from but it's been around for a long time.
11 May 2015 16:24 #4337 by AJ WH Ranger
Replied by AJ WH Ranger on topic Routine Maintenance
It look like a housing for a small air pump cut in half.. :)
11 May 2015 16:32 #4339 by nappypappy
Replied by nappypappy on topic Routine Maintenance
Deck in the way.... Front mount it
....I cant say enough good about it.....
11 May 2015 18:13 #4344 by Geno
Whatever it is I have to have one! :woo
12 May 2015 09:20 #4373 by nappypappy
Geno wrote: Whatever it is I have to have one! :woo
Well if you look around your shop you mostly have two or three of whatever... :wave
12 May 2015 12:05 #4378 by Geno
If I had one of those I'd know it. I thought about just cutting a piece of PVC pipe in half for starters, then I would have 2. :thumb
12 May 2015 13:24 #4385 by nappypappy
Geno wrote: If I had one of those I'd know it. I thought about just cutting a piece of PVC pipe in half for starters, then I would have 2. :thumb
Good thinking....twos better than one.... :smile2
