Disc Harrow lock pin
15 Feb 2021 15:20 #16749
by whnewone
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
Disc Harrow lock pin was created by whnewone
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
15 Feb 2021 17:47 #16750
Replied by Geno on topic Disc Harrow lock pin
I love hard to find lol. Did you get the part # while you were on PartsTree or do you have one?
15 Feb 2021 17:56 #16752
by whnewone
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
Replied by whnewone on topic Disc Harrow lock pin
I believe that is the correct part number from parts tree. Yes 2156, partstree and the correct term is lever lock pin.
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
15 Feb 2021 18:01 #16753
by whnewone
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
Geno, unless they changed it, I have look at all single row disc and they have the same part number. I believe it is a DP-861. The disc has been painted black by the PO(s). Unfortunately they painted over all decals. I have a manual purchased for the DP-861. While I have you here what would be good to remove paint without harming the decals?
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
15 Feb 2021 18:09 #16754
Sorry I missed it Bill, I saw it the 2nd time looking at your post, busy day...
I have one here NOS but only the 1. I should be able to use it for a pattern to make them but I need to take some measurements and see if I have the rod stock here and if my standard rod bender has a die to make them. It's time for me to finish up for the day is it ok if I get more into this tomorrow?
15 Feb 2021 18:19 #16756
Thanks, I'll get into it in the morning.
15 Feb 2021 18:21 #16757
Believe it or not carb cleaner sprayed on a shop rag works good for me, it really depends on the type of paint and how much there is. Terry (Vinylguy) prob has new decals for it as well.
whnewone wrote: Geno, unless they changed it, I have look at all single row disc and they have the same part number. I believe it is a DP-861. The disc has been painted black by the PO(s). Unfortunately they painted over all decals. I have a manual purchased for the DP-861. While I have you here what would be good to remove paint without harming the decals?
16 Feb 2021 10:09 #16759
Morning Bill.
I have the dies I need for the bender and everything is good minus the stock. I don't stock 5/16 rod nor does anyone else close by. My metal supplier isn't picking up so they may be closed from all the bad weather and ice around here. I hope it's not like the 9/16" rod, it costs a lot more than 3/4" rod, they say it's a supply and demand thing. If you're not in a big hurry I'll keep on it as far as the rod stock and check on cost and availability. I'll be making another steel order in 2 weeks or so after the weather breaks and I get the new iron worker in here and set up so it will be at least that long before I could make them.
I'll prob make them regardless since I have them all figured out now but I didn't know how big of a hurry you were in.
Time to create page: 0.279 seconds
