ONAN ID
Geno wrote: Charging goes through the very problematic fuse block. Check the fuse and block first, then the 9 pin Molex connector between the battery and rear of engine next. That's where 90% of charging problems go back to.
ok will check that and at the Molex on the outside of it somebody spliced the red wire to a white wire.....
Did look at the Molex and can tell why the wire is out side of it ...looks like there was a short since its got a little black in there.......so the splice makes sense or at least to me for now............:smile2 :smile2
