New Techy carbs
05 Jun 2015 11:26 #5381 by JustinW.73
Replied by JustinW.73 on topic New Techy carbs
Ok. Let me know
05 Jun 2015 11:58 #5382 by Geno
Replied by Geno on topic New Techy carbs
The most popular carb numbers are 632230 / 632272 and are interchangeable. It won't have a primer on it Justin. :)
05 Jun 2015 14:36 #5385 by AJ WH Ranger
Replied by AJ WH Ranger on topic New Techy carbs
The only stamped number on the carb I pulled off was 8514A17..
I guess it would help to know that this paticular tractor doesn't have the original Techy. Someone swapped the original Techy with another Techy! :confused1 :beat
05 Jun 2015 14:40 #5386 by AJ WH Ranger
Geno wrote: The most popular carb numbers are 632230 / 632272 and are interchangeable. It won't have a primer on it Justin. :)
Geno do have any engines laying around? I'm tired of messing with these Techy's! All I want to do is mow my lawn! :angry2
05 Jun 2015 14:53 #5388 by Geno
I'm about 15 or more engines short now not counting 20 or so I haven't had running yet. :doh
What are the engine numbers on that thing.
05 Jun 2015 15:04 #5389 by JustinW.73
Ok then AJ that second carb will work. They are all the same size for those. Just make sure its for the same model # on the engine.
05 Jun 2015 15:05 #5390 by AJ WH Ranger
Not sure on the numbers. I will look when I get home.
05 Jun 2015 15:06 #5391 by JustinW.73
AJ WH Ranger wrote: Not sure on the numbers. I will look when I get home.
Ok. All you need is the model number on the ENGINE. Then I can check for you. If it isn't I can find one for you too.
05 Jun 2015 15:26 #5392 by Geno
This one fits the most popular numbers for the H50, H60 + HH60 - Link
16 Jun 2015 10:01 #5877 by AJ WH Ranger
Geno wrote: This one fits the most popular numbers for the H50, H60 + HH60 - Link
Just bought this carb... Hope it does the trick! :waiting
