Engine Lubrication, Let's Talk
The main use of ZDDP is in anti-wear additives to lubricants such as greases, gear oils, and motor oils, which often contain less than 1% of this additive. It has been reported that zinc and phosphorus emissions may damage catalytic converters and standard formulations of lubricating oils for gasoline engines now have reduced amounts of the additive, though diesel engine oils remain at higher levels.[4] Crankcase oils with reduced ZDDP have been cited as causing damage to, or failure of, classic/collector car flat tappet camshafts and lifters which undergo very high boundary layer pressures and/or shear forces at their contact faces, and in other regions such as big-end/main bearings, and piston rings and pins. Roller camshafts are more commonly used to reduce camshaft lobe friction in modern engines. There are additives, such as STP(R) Oil Treatment, and some racing oils such as PurOl, Brad Penn and Valvoline VR-1, which are available in the retail market with the necessary amount of ZDDP for engines using increased valve spring pressures. The same ZDDP compounds serve also as corrosion inhibitors and antioxidants.
Here's my take on this, Kohler engines used in our tractors are flat tappet engines with stiff valve springs thus requiring a zinc additive. B&S on the other hand have very weak springs which would not suffer from the new Federal oil requirements. At this time I am inclined to add some Lucas TB Zinc-Plus Engine Break-In Oil Additive to all of my Horses to restore the proper amount of zinc protection to the engines.
What say you?
- Away
First thing I wondered is if they are using something else to compensate for the zink. You would be surprised at the engines still out there today that are solid lift, especially a lot of foreign cars. There's also the demand of turbos, and higher rpm limits have been showing up for years. They've gotta be compensating for that somehow.
Next thing I wonder is if this will pertain to any 30 weight oils as they are never used in autos anymore. I need to give my oil distributor and Mobil a call.
- Away
blog.hemmings.com/index.php/2012/10/18/t...ts-on-older-engines/
Wow nice article.........:smile2M Bailey wrote: Here is a good article from Hemming's on the subject zddp content.
