Carson's C-121
  • Away
03 Jun 2026 18:15 #19039 by Geno
Here is the 2nd post for today, the rear hitch work.  It was grandpas hitch on the tractor when it got here.  It will look good when done.
The first pic with the new pulleys I took Monday so I wouldn't forget to get some kind of before pic.  The pulleys had just come in because I had only 2 left in stock.  It's also the idler pulley that goes on your main drive belt Carson.
I did the rear hitch yesterday.  It was cleaned up in all the spots where it needed to be welded then welded back together.  The center bar had been replaced before but only welded on one side, big no no.  When you do that you can just fold it in and break a weld that small by hand.  It also never got any real penetration as you can see in the cross bar pic.   Everything was cleaned up, squared up, and welded on all sides, it wont break again...
After that all the parts were blasted and it's all ready for paint.
Today was getting dash and side panels that would work, will get those pics up tomorrow.
  • Away
04 Jun 2026 18:30 - 04 Jun 2026 18:32 #19040 by Geno
Spent a lot of time saving the original panel that holds the ammeter and ID tag.  I didn't have much choice, it's another piece that was only on 78-79 C series and I didn't have one any better.  Most of it done with the DA and a lot of sanding.  The 2nd pic shows just how fine the metal is the DA takes off, it's like metal dust, lots of work, time, and sand paper to take that much off...
The bottom shift plate faces up and it would take all day to save it so it was replaced, 3rd pic.  The replacement is shorter but still goes under the rear fender, just not as much.  The longer panel went way under the rear fender.  It's one of the things they changed after 79 to make it easier to get out.  I went over it with the DA also so it wouldn't show the really smooth places where the decals were because the decal kit is different for the 79.
Spent a lot of time yesterday and today looking for really nice side panels and found some super nice ones.  Will get them ready and post more on that tomorrow.
Last edit: 04 Jun 2026 18:32 by Geno.
  • Away
05 Jun 2026 19:05 - 05 Jun 2026 19:05 #19041 by Geno
2 posts today, this is #1.  1st pic is just a bunch more hours spent fixing and getting the next pile of parts ready to paint.
Spent all day yesterday pulling side covers from all over and blasting them to find some really nice ones.  The 7th belt guard and 5th lift arm cover was the charm.
This tractor is supposed to be of show quality as possible without getting too crazy so I also needed a belt guard that looked good looking at it from the inside at least where it shows when looking between the motor and battery.
Last edit: 05 Jun 2026 19:05 by Geno.
  • Away
05 Jun 2026 19:44 - 05 Jun 2026 19:46 #19042 by Geno
This is the 2nd post.
Today was front wheel day all day long and didn't get anywhere.  I had one nice one in the shop I blasted, but couldn't find another like it that was easy to get to get to match.  Most peeps don't know there are over 10 different types of front deep dish wheels.  If they're getting replaced and a nice wheel costs what it costs no matter the variation they should both match.  The one blasted in the pic is the same as original minus the extra inset from the outside and bump on the inside to make a better seal on the tire, make them stronger, and they have a wider cone in the center.
 There are differences in how deep the dish is, how much the center protrudes (a few variations), bumps or no bumps, angle of the wheel near the center (a few variations), how far the center bearing pipe sticks out per side (a few variations), the curl on the outside of the rim (3 variations).  I started pulling tractors in with the forklift with really nice looking rims on the outside but never found anything decent on the inside.  Most of them had fix-a-flat in them at some time that will eat up a rim faster than anything.  So I didn't get anywhere today and don't have days on end to do this anymore.  I knew it would be tough is why I didn't do it in the beginning when I did the rear wheels.  If the insides aren't a concern I have a lot of options.
If the insides are a concern I have some HD NOS tire and wheel assemblies in the back.  I got one set out that matched, removed the tires and the wheels are in the last pics.  They are dirty and dusty and a few marks were made getting the tires off, and the inside black is just really thin rubber debris from where the tire was on it but they are new.  They are expensive but I'm not sure what else to do at this point.  I'm open to whatever you would like to do but rims don't exist hardly anywhere at all (other than here) let alone something really nice.  They are actually a HD rim with a thicker metal, thicker bearing pipe, and strong curl on the outside you can see in the last 3 pics.  They were an option if someone put a 2 stage snow blower, front end loader, or something heavy that required a heavier front wheel.
Last edit: 05 Jun 2026 19:46 by Geno.
  • Away
11 Jun 2026 17:48 #19046 by Geno
There's a pic of some of the decals below.  One of them is the ID tag decal that goes over the original ID plate.
Started blasting the front wheels and the next weakest link took the blaster down again.  It quit putting out media and I found the problem, this piece seals the pressure pot so it will blast.  If I could find a 4" urethane ball I could cut it in half and make one...  Last year the metal stem came out so I made a new one.  I wish I could find a ball to cut in half and get it going again for now.  Get one thing working back like when it was new and the next weakest link shows up sometimes...
Last pic is where I replaced the metal rod in it last year.
  • Away
12 Jun 2026 11:26 #19047 by Geno
I sent pics to Blast-it-All to let them look at what happened and they said the parts in it were from who knows where.  The pop up should be a blue urethane.  I just ordered a new pop up and upper seal from them directly a few minutes ago.  They also said the elbow inside was slightly to the left like seen in the pic and it should be straight up so I'll straighten it out this weekend.
I told the tech guy I had it dialed up and working it harder than it should to save some parts on a job (your tractor Carson lol) so I need to put it back to somewhat normal settings...     I told him I ran aluminum shot in it and he said it won't do that like I'm usually told by them.  After he saw the pics and modifications I made to pull the heavier aluminum to the pot he did compliment me and said I seemed to have a good grasp on airflow and what I did was smart and done right.  I told him I worked briefly in one of the only 2 independent wind tunnels in the US right here in town that did aerodynamics on vehicles about 40 years ago so I had a good concept of airflow.
They said they had the parts in stock and should ship today.  They are in NC so I think they will be here beginning of next week.
  • Away
18 Jun 2026 18:36 - 18 Jun 2026 18:42 #19058 by Geno
Hey Carson, I just got an email a little bit ago from TSC that the rebuild kit for the metering valve is ready to be picked up.  I printed out the email I need to get it and will pick it up first thing in the morning so I can wrap this thing up and get back to blasting on yours.  Everything else on the blaster is done minus moving it back where it belongs.
If you or dad want to check out what's been going on with it while waiting on parts and what happened to it in more detail you can see it here -  More blaster work
Last edit: 18 Jun 2026 18:42 by Geno.
18 Jun 2026 19:41 #19059 by Carson
Thanks Gene for all your hard work, keep it up 👍😄
  • Away
19 Jun 2026 19:07 - 19 Jun 2026 19:08 #19060 by Geno
I should be thanking you for being so good to me and understanding the blaster delays so thank you.
I forgot I had an appt with the peeps setting me up with my Medicare stuff this morning until I looked at the schedule.  I'll be 65 in October, didn't know anything about this stuff, and the peeps I'm using are wonderful.  They come here for everything and we can actually go over everything face to face, and we fill out paperwork together.  It's a 100+ year old company that still does things the old fashioned way and I really like that.
I went and got the parts for the blaster after they left, got it all back together, turned it on and started to blast one of your front wheels, then the afternoon was filled with peeps again...  The blaster has never ever worked so good as long as I've owned it so we are back in business.   I just finished one of your front wheels and it's like new.  Will do the other early tomorrow morning when peeps don't know I'm here lol.  Hopefully tomorrow will be quieter than it has been but at least we can get back to work on yours now as the priority minus walk ins.
Last edit: 19 Jun 2026 19:08 by Geno.
  • Away
20 Jun 2026 17:53 #19062 by Geno
2 posts today.  2 new HD front rims blasted and ready for paint.  The blaster is working better and faster than ever so that will help things move along a little faster.
I also pulled the flywheel to check under it and make sure there wasn't any aluminum shot under it.  While in there I cleaned up a little and sanded the stator poles.  It's already back together and torqued.
