10 Mar 2017 07:04 #13486 by GT 14
That is a bullet proof front end!! :bow2
  • 23 AUTOMATIC LSE
13 Mar 2017 00:05 - 13 Mar 2017 00:16 #13504 by 23 AUTOMATIC LSE
Thanks Geno and GT, "Bullet proof front end" for sure. I hope no one tries to shoot it, LOL. Now it's time to move onto the hopefully bullet proof back end, for just a bit of an update.
82.) Right-hand Transaxle Case
83.) R.H. Front Needle Bearing {1532} Installed, outside, inside
84.) R.H. rear Needle Bearing {1532} Installed, outside, inside
85.) Oil Filter Fitting, Installed
86.) Dowel Pin, Installed
87. - 88.) Ditto 82 - 83 for Left-hand
89.) Ditto 84 but uses {8049}
90.) Ditto 86 for Left-hand
Last edit: 13 Mar 2017 00:16 by 23 AUTOMATIC LSE.
  • Away
13 Mar 2017 07:37 #13505 by Geno
Wow, didn't know you were rebuilding the rear as well. :woo
13 Mar 2017 07:43 #13506 by GT 14
:bow1 :surprised :bow2
  • 23 AUTOMATIC LSE
15 Mar 2017 13:00 #13520 by 23 AUTOMATIC LSE
Yes, the only way to know what's in them is to open them up, besides I am converting to the larger bolts bull gear, end caps, and locknuts, not to mention the longer axles for duals. Does anyone know what the purpose of the allen set screw is, that is near the needle bearing in the lower part of the first pic, and just right of the right needle bearing in the second pic?
  • Away
15 Mar 2017 19:23 #13524 by Geno
Does anything sit there inside when it's assembled? If not it's probably just a plugged extra hole. :)
  • 23 AUTOMATIC LSE
15 Mar 2017 21:17 #13527 by 23 AUTOMATIC LSE
This area gets covered by a gasket, and the gasket gets covered by the motor.
  • 23 AUTOMATIC LSE
22 Mar 2017 20:01 - 22 Mar 2017 20:04 #13556 by 23 AUTOMATIC LSE
Parking Brake Pawl
91.) Parking pawl
92.) Parking shaft
93.) Spirol pin
94.) Installed
95.) Seal
96.) Inserted in case
97.) Shaft inserted in case
98.) Brake lever assembly
99.) Spirol pin
100.) Inserted in lever
101.) Installed on shaft
Last edit: 22 Mar 2017 20:04 by 23 AUTOMATIC LSE.
22 Mar 2017 20:18 #13557 by nappypappy
:10 :woo :10 :smile2
  • Away
22 Mar 2017 22:41 #13562 by Geno
Definitely better than factory. :10
