What's everybody doing?
02 Nov 2016 16:42 #12602 by Geno
I had the same problem with the light rear end Kurt. I got hung really bad last year so I put smaller fluid filled tires on it, chains with teeth, and built a box that goes over the top plow mount to stack weights in. The weights are 55lb I think and there's 6 back there. It was probably overkill but the thing would go anywhere lol. :rolling
02 Nov 2016 17:11 #12604 by Kurt-NEPA
We are think alike Geno. This is just about what I did. I used 5 - 25 lb. barbell weights in addition to 70 lb. cast wheel weights. I can add more barbell weights if I need to.
I was using the 70lb cast wheel weights and chains with my single stage and that was not enough when I tried to back up - up hill with the blower raiseed. I thought my two-stage was going to need more - much more.
Also, I'm going to try some rubber chains this year. We'll see - the steel chains are ready to go on if need be.
Sorry, but the system won't let me post pictures.
Kurt
02 Nov 2016 17:47 #12610 by Geno
I never tried using rubber chains, I never thought they would be good on ice. I'll look into the pic thing. :)
02 Nov 2016 18:10 #12612 by Kurt-NEPA
Pic thing is working now! Thanks,
I've never tried rubber chains before. They get good reviews. Steel chains were making a mess of my driveway, so they are worth a try.
I agree with the ice comments, probably worthless.
Now that pics are work, below is a pic of my hitch and weights.
Kurt
02 Nov 2016 20:00 #12616 by Geno
That is super sweet, and easier to take on + off. Send me the plans please. :)
02 Nov 2016 20:20 #12618 by Kurt-NEPA
Plans, you think I have plans...........
Actually it was quite simple. I purchased a 2" receiver tube. Add some 3X1-1/2" channel and some 1-1/2" angle and I have a hitch.
Here is a pic with some other weights I tried.
03 Nov 2016 08:06 #12620 by Kurt-NEPA
Here is another pic Geno. Wish I had taken more. It shows the main body as I was painting it. If you want some dimensions, just ask and I'll get some.
Also, I made some supports that go from the main hitch down to the rod through the original hitch. I made them from 1 X1/8" steel welded to a couple of spacers made from 3/4" pipe. I bolted these to the upper hitch just so I had some adjustment. This hitch worked well, it easily held my 260lbs. Simple to remove too if I put my plow on.
03 Nov 2016 08:31 #12621 by Geno
Thanks Kurt. :thanks
05 Nov 2016 05:56 #12623 by GT 14
Did the free weight thing myself with a 2" receiver.
05 Nov 2016 07:26 #12624 by Geno
I remember that now, what tractor was that on?
