New Member 416-8 Onan
- GoBucks
- Junior Member
I then drove from Huntsville, AL to Indianapolis to buy the 416. I did some major sanding and painting originally, I never got around to the hood or fenders though.
Now, it's really hard to start when cold, even though I keep it on a trickle charger and after getting a new battery. The oil gets really dark in a hurry. It runs really good though, and has plenty of power. It doesn't really smoke, except when I first start it and then when I power it down. I thought it might need a rebuild, but the shop thinks it's a combination of the starter (which I also guessed, due to a similar problem with a car once.) The shop also thinks it could use a carb rebuild.
So, new starter, carb job, basic oil change, blades sharpened, etc. parts would be a little over $1,000, labor is $50 an hour, he guessed it would be $1,500 or more total.
A standard Cub Cubet, etc, just won't work too well. I have a small yard, but the front yard is a hill with a retaining wall. It's between 30 and 45 degrees. With the the Wheel Horse, I can put it in LOW range, and it climbs like a goat. Which is my concern with new/used tractors, even Hydros, would I be able to prevent wheel spin? I considered going to Home Depot or Lowes, buying a Cub Cadet, trying it, and returning it if it slips to much. I really like the Wheel Horse(s) though, and don't know that I will be living at this house forever. Someday I may move to a larger yard, or up north and need a snow blade, etc. My only negative on the Wheel Horse is it cuts too low.
I have a few options:
1. Fix it, but it will still need an engine rebuild in a few years, due to the dark oil.
2. Leave it and run it as it is, mabye just use a battery charger/booster to jump start it. See how long it lasts, just change the oil, etc.
3. But a Restored or used Wheel Horse
4. Re-Power it. I was directed here because of the work GT14 did. So, there are two sub options here.
4a. Harbor Freight Engine, $700
4b. Honda engine with wiring, etc complete kit for $2,180
So, any suggestions, option #1 seems to be out, unless I can find a starter motor rebuild kit instead.
- Away
The first thing to consider is do you want to keep that tractor. Everything I do is based on cost unless there is sentimental value which is valid, like it was Dad's tractor.
If keeping the tractor is not an issue, from the figures I see it is cheaper to buy another even if it's just like it.
If you want to keep the tractor, it depends on what you want to do financially, put off the repairs to an engine that is prone to fail, or make a change now. I feel spending any money on this engine may be a waste of money in the future. The rebuild cost on an Onan is out of sight as well. The repower like GT did cuts to the quick and takes the money used in the repair of the Onan now and in the future and applies that money to a better engine that I feel will last longer, and have a lot more power. The tractor will last you as long as you want it to with proper maintenance, the engines were the only real problem with that tractor.
Buying anything newer would be completely out of the question for me. Everything is pretty much MTD manufactured and will need a lot of money spent on it in just a few years. That fact alone is what keeps us in business selling and restoring older, more reliable tractors that can last a lifetime.
Would love to hear what everyone else thinks.
- GoBucks
- Junior Member
- Away
- JERSEYHAWG
JERSEYHAWG wrote: that repower Gene talks about is probably your best / cheapest route. the onan rebuild is not for the weak of wallet, and might not work. best of luck.
:agree :smile2
Geno could do it before his first coffee break.
- GoBucks
- Junior Member
The engine swap is still my first choice, if I can get the mechanic to do the HF engine swap.
GT14, didn't you have to make your own engine mounts as well?
How hard was it to relocate the ignition switch to the dash, the wiring, etc?
What isn't just plug and play or that can be purchased anyway?
For the price difference, I'd just stick with the 22HP twin you had, it seems to sound like the Onan!
The mechanic/shop is closed until Wednesday, so I'll see what he says then. He had also mentioned the possibility of a re-power solution, he was going to look into it as well. The mechanic is on Redstone Arsenal here in Huntsville, at the Small Engine Repair shop:
redstone.armymwr.com/us/redstone/redston...ls-center?eID=590759
Thanks,
Sam
- Away
I made new motor mounts using flat stock. (engines needs to be moved left to line up)
Wires just need to be extended for the starter.
I reused the original choke and throttle set-up.
Just need a bushing for the clutch and maybe a new drive belt. (depending on where the engine ends up)
Pepper Pots mufflers are the cheapest alternative, I made flanges for the engine (block is not threaded) and welded 1" pipe on them to mount the pots. If you have clearance you might be able to use the muffler that comes with it (but its BIG)
