520H Rear Axle Oil Seals
- Kurt-NEPA
28 Mar 2015 10:27 #2124
Update. I tried the screw approach. The metal was too soft and screw pulled right out, but it did give me hole to pry on. A couple of holes about 3/4" apart and I was able to pry the metal up and out of the way. Then I was able to collapse the OD of seal and pull it out. So I declare success. The new seal is in, the hub has a new key way, and I'm back in business. So far no leaks. I don't like the condition of the key way on the axle, But a least the hub is tight. I'll keep an eye on it.
Thanks for the help.
28 Mar 2015 11:11 #2127
There is more than one way to skin a cat.......and the cat hates them all.
28 Mar 2015 13:16 #2138
you win a war one battle at a time, one down with more to go.
if you need to change the game plan at half time that is fine when you post a WIN in the end
- Kurt-NEPA
28 Mar 2015 14:40 - 28 Mar 2015 14:41 #2148
You got that right jm. This just one battle won. Its about 10th on this tractor. Only about 143 (+/-) to go.
jm46322 wrote: you win a war one battle at a time, one down with more to go.
Last edit: 28 Mar 2015 14:41 by Kurt-NEPA.
- JERSEYHAWG
28 Mar 2015 16:14 #2152
by JERSEYHAWG
Replied by JERSEYHAWG on topic 520H Rear Axle Oil Seals
yo yo yo,,,,kurt, wheres that blower re build at? saying hey gang here to,,,,,,,fishing my way around here………..
- Kurt-NEPA
28 Mar 2015 16:31 #2155
It's coming along. I got the auger/impeller shaft with the rebuilt gear box all ready to go. I'm waiting for some warmer weather to do some painting. It got up to 27 today with flurries, so not much progress. Where is spring?
I'll post some pictures as I make more progress.
JERSEYHAWG wrote: yo yo yo,,,,kurt, wheres that blower re build at?
