Removing exhaust pipe
13 Apr 2015 19:28 #3189
Removing exhaust pipe was created by Geno
Looking to see what works best for getting these pipes out of the engine blocks. What has worked best for you guys?
I asked Sandra if she wanted a stack, she said "well duh". :rolling
Here's what we're working on -
13 Apr 2015 19:41 #3190
Replied by M Bailey on topic Removing exhaust pipe
Geno I've had good luck with an 18" Rigid pipe wrench. Easier to remove if the block is warmed up first and a little Kroil on the threads helps out too!
13 Apr 2015 20:20 - 13 Apr 2015 20:21 #3191
Replied by Trouty56 on topic Removing exhaust pipe
OK...here is what I do....I cut the pipe off about 1/2 inch away form the block.....then take a sawzall and cut the pipe at two places longwise....not quite through but enough to weaken the pipe wall....then take a punch and hammer it towards the inside.....
Last edit: 13 Apr 2015 20:21 by Trouty56.
13 Apr 2015 20:25 - 13 Apr 2015 20:25 #3192
Replied by Geno on topic Removing exhaust pipe
You ever try the big honkin pipe wrench Bob?
Last edit: 13 Apr 2015 20:25 by Geno.
13 Apr 2015 20:33 #3194
No....I was always afraid to break something......pipe is cheaper to me.....but give it try if you like....
13 Apr 2015 21:22 #3198
by JustinW.73
Replied by JustinW.73 on topic Removing exhaust pipe
What I do is dab a little oil here, some there, and break out the heavy artillery!
www.menards.com/main/plumbing/plumbing-t...p-1339101-c-8615.htm
- Sandra
- Platinum Member
- Ninja Bacon Huntress
13 Apr 2015 22:55 #3202
by Sandra
Replied by Sandra on topic Removing exhaust pipe
Well duh. :smile2
- Bobster
13 Apr 2015 23:09 #3205
by Bobster
Replied by Bobster on topic Removing exhaust pipe
I soaked mine for about 4 days with PB Blaster. Used a sharp chisel to break it loose. Worked but I was sweating all the while.
14 Apr 2015 06:46 #3221
Replied by GT 14 on topic Removing exhaust pipe
Warm it up and use the big Honker!
:cents1
14 Apr 2015 08:04 #3230
I've been putting PB Blaster on it for about 5 days. I got out the 2' pipe wrench and took a hammer to the end of it and gave it some hammer action and she came out. I like hammer action better than constant pressure, seems to break less things overall, sort of like an impact. Thanks for all the advise guys.
Now I'm off to start a stack thread to see what you all have done so Sandra can see them. :smile2
