Transmission Seals
  • Away
11 Dec 2015 09:04 - 11 Dec 2015 09:08 #9504 by Geno
Transmission Seals was created by Geno
We've started stocking transmission seals, all in SKF brand. We will be putting them in the store when we get a chance. We figured if someone can't get them locally, or just needed some while ordering other things from us we would have them available to make things easy. :)
Prices will be the same as Motion Industries, which are the cheapest around, and from making an order this morning to check their freight prices, we will be around 1/2 the freight cost.
Last edit: 11 Dec 2015 09:08 by Geno.
11 Dec 2015 11:24 #9505 by motor12
Replied by motor12 on topic Transmission Seals
Why not put together a package deal that includes bearings, seals, gaskets and bushings for some of the older transmissions. That way it's one stop shopping and the guy buying knows he has the correct parts. As everyone knows when you crack a case you will need all that stuff when she goes back together. Just a thought..
  • Away
11 Dec 2015 12:09 #9506 by Geno
Replied by Geno on topic Transmission Seals
In time that will all happen Motor. :thanks
We haven't gotten into ordering larger quantities of the the bearings and bushings yet but eventually will. As we find we use more things in the shop, we seek out a direct distributor where we can try to keep cost down and order more in bulk, like with the seals.
Eventually there will be rebuild kits for the transmissions, tillers, sickles, and most everything else. :)
