29 Jan 2017 17:05 - 29 Jan 2017 17:06 #13213
>( >( ok but that would look nice on mine even if it didn't fit right .....:smile2
Geno wrote: They won't fit yours Nappy, it has a whole different setup.
Last edit: 29 Jan 2017 17:06 by nappypappy.
- 23 AUTOMATIC LSE
01 Feb 2017 07:36 #13221
by 23 AUTOMATIC LSE
Just a bit of sorting to do prior to uploading the next post as I have 1 wheel / tire that did not hold air. I am sanding down the rim on this wheel where the bead goes. I will then finish with the paint and reassemble hoping that this takes care of the leak.
01 Feb 2017 09:29 #13224
I have a few front wheel bearings here. Looks like they don't exist anywhere at all, I do have a call into Heim who made them and will let you know if I come up with anything.
Fastenal should have or be able to get the lock nuts.
01 Feb 2017 09:36 #13225
What is the model # on your tractor Mark? Is it a 1-600, 601, 610, or 620?
- 23 AUTOMATIC LSE
26 Feb 2017 21:34 - 26 Feb 2017 22:16 #13426
by 23 AUTOMATIC LSE
After reassembly of the tire to the wheel, I tested it in water and found out that the leak was due to a faulty core in the valve stem. I also was able to purchase a couple of the #104396 Ball Flange bearings {New Old Stock} but had already taken pics with the used before they arrived.
48.) Left Spindle
49.) Left Inner Shim .050
50.) Left Inner Shim .015
51.) Left Wheel Assembly
52.) Grease Zirk
53.) Zirk Installed
54.) Valve Stem {Non O.E.M.} I have C3 Corvette Flags valve stem caps I will be using instead of the plain chrome shown
55.) Valve Assembly Installed
56.) N.O.S. Ball Flange bearings
57.) Bearings Installed
58.) Tire Installed on Wheel
59.) Wheel Tire Assembly on Spindle
60.) Left Outer Shim .015
61.) Left Outer Shim .050
62.) Left Thick Washer
63.) Nyloc Hex Bolt {Non O.E.M.} Greased Bearings
64.) Hub Cap {New Old Stock}
65 - 81.) Ditto for Right Side
Next update may be awhile as I have quite a bit of sorting to do with the hydro transaxle and dual ag tires / wheels before I can proceed
48.) Left Spindle
52.) Grease Zirk
53.) Zirk Installed
Last edit: 26 Feb 2017 22:16 by 23 AUTOMATIC LSE.
26 Feb 2017 21:43 #13427
I must say you do some mighty fine work.............
:smile2
- 23 AUTOMATIC LSE
26 Feb 2017 22:13 #13428
by 23 AUTOMATIC LSE
Thanks, Nappy, it is nothing anyone else couldn't do if they wanted to!
27 Feb 2017 07:24 #13430
Nice work Mark.
- 23 AUTOMATIC LSE
06 Mar 2017 18:47 #13476
by 23 AUTOMATIC LSE
Took some pics of the right side front wheel / tire assembly with N.O.S. bearings installed and also both wheels / tires on front.
Next the hydro trans-axle and motor {hydro}.
06 Mar 2017 20:03 #13477
Oh baby.
