Starting Fluid - 520H Onan
- GoBucks
- Junior Member
25 Jun 2018 14:44 #14699
by GoBucks
Starting Fluid - 520H Onan was created by GoBucks
So, it cranks, but doesn't fire. If I add a little starting fluid it starts right up. This is only need for the first start of the week, if I cut it off, wash it off, etc, and get back on, it starts up fine.
Note, I was out of town for a month this time. I posted about the fuse holder, it's cranking now and just before I left at the end of May. Both times though, it didn't want to fire.
Any tips to lead me in the right direction?
Fuel filter?
Carb adjustment?
Fuel pump?
I replaced 1 spark plug before my trip. Yeah, only 1, short on time and the Previous Owner put in a full size car battery, so I can't easily get to the 2nd until I pull the battery.
Thank you,
Sam
Fuel filter?
Carb adjustment?
Fuel pump?
Thank you,
Sam
26 Jun 2018 08:18 #14700
Hey Sam. Have you tried taking the fuel line off at the filter and cranking it to see if the fuel pump is pumping?
- GoBucks
- Junior Member
26 Jun 2018 11:13 #14701
by GoBucks
Question, are there supposed to be 2 fuel filters on the 520H? Mine has one under the fuel tank and one by the fuel filter.
N0, I haven't tried it yet.
26 Jun 2018 15:12 #14702
Should have only 1 fuel filter above the engine.
- GoBucks
- Junior Member
01 Jul 2018 17:28 #14707
by GoBucks
Saturday morning, I went out to cut the grass, it cranked but wouldn't start. I then removed the hose on the input side of the fuel filter, cranked a couple seconds and gas spurted out.
So, is there a carburetor adjustment I can make to fix the No start issue? It runs great once started, and will start up again no problem.
Thank you,
Sam
Thank you,
Sam
- GoBucks
- Junior Member
01 Jul 2018 19:47 #14708
by GoBucks
FYI: I did replace the spark plug wires this spring.
Looking into this, it sounds like the choke might be sticking or the needles in the carb are stuck?
- GoBucks
- Junior Member
06 Jul 2018 10:32 #14713
by GoBucks
I figured it out, the Choke wasn't closing all the way. I took the air cleaner off, pushed the choke down all the way, and it started right up. I hit it with some carb/choke cleaner last night, I'll do it again this morning on the outside of the carb and see how it does.
- GoBucks
- Junior Member
14 Jan 2019 14:46 #15120
by GoBucks
The problem is the choke doesn't close all the way.
How do I adjust it? I sprayed choke cleaner inside and out.
I disconnected the choke cable where it attaches to the carb. I then pushed the choke down all the way to close. I re-attached the cable. No luck, when I moved the choke cable up and down, the choke still wouldn't close all the way.
Thank you,
Sam
Thank you,
Sam
14 Jan 2019 15:02 #15121
Does it seem like the choke is binding? Close the choke all the way with the adjustment loosened, then pull the choke lever up just a little (1/8") like you're choking it, then tighten the adjustment screw it should close fine.
- GoBucks
- Junior Member
28 Jan 2019 14:41 #15163
by GoBucks
Should the choke close completely?
520H choke
520H choke
