Carson's C-121
27 Aug 2026 18:55 #19126
The steps got the new step treads, bolt clips, + rear fender bumpers put on this morning. The new certification decal is on the left side guard, and the first ever new Magnum air filter cover decal from my decal guy is on. I got 2 new NOS shift knobs out of the back for it, they are in the pics as well. Everything looks great.
Next up was getting it started up. The panel with the charging gauge, battery, a temporary muffler (it has to have back pressure) was put on, and fuel put in the tank. A few other little things were finished up and it was time to fire it up. It runs fine on carb cleaner but not on it's own. Fuel pump brought fuel to the front in the first few seconds but something is going on in the carb. Nothing new really, things happen when steam cleaning them sometimes. Things get pretty hot for awhile when steam cleaning and moisture develops inside things from all the quick heating. There could be something in the fuel bowl that broke loose and stopped up the main jet or the fuel input valve may be stuck in the seat.
It's already quitting time again so the carb will get removed in the morning to check it out. Other than that it purs like a kitten, charging system is at 14V, and everything else wiring wise is working like it should.
28 Aug 2026 18:59 - 28 Aug 2026 19:00 #19127
I took the carb off this morning and there was some rust in it from the heat of the steam cleaner. It was all cleaned up and polished with 0000 steel wool and it's new inside again. After that it fired right up, the carb was set, it was run for 20 minutes to check for leaks, and the running part is done.
After that there were some other little things done so all of the panels could go on. They are all on and all lined up perfect.
It's quitting time again so that's it until next Monday.
Last edit: 28 Aug 2026 19:00 by Geno.
29 Aug 2026 11:49 #19128
LOOKS BETTER THAN NEW...GREAT JOB....
31 Aug 2026 19:01 #19130
Thanks Nappy.
***** QUESTION. The first pic shows tail lamp options. I can put LED lights on the back and they are pretty cheap. The original NOS lamp holder, lens, and felt insulator costs over 10 times the price but they are original and the only ones I've ever seen I have. I only have 4 of the NOS lenses left so they come at a premium cost as they don't exist. The original parts are part #8041, 8042, and 8044. If you search the 8042 lens for instance everyone sells the superseded part #112564 which was used on the newer tractors. I have them as well but they are a lot taller, not original, and come at a higher cost than the LEDs. The choice is up to you.
***** QUESTION. Next thing I ran into is the hood will not close with the magnum plastic cover on it. The motor is not a problem but the air filter cover as you can see in the pic is a problem. The best way to remedy this is with a 16HP older K series cover. The Magnum 14 and the K series 16HP both use the same air filter so the metal cover works perfect on it. I would just like your approval to do that.
- Carson
- Member
05 Sep 2026 08:31 #19133
by Carson
Hello Gene, I would like to go with the LED rear lights, and yes you can put the k series air filter on it
05 Sep 2026 18:11 #19134
08 Sep 2026 18:39 - 08 Sep 2026 18:41 #19137
Left you a message about 25 mins ago. 2 posts today, this is #1.
Weather was good yesterday morning so I repainted the 3 piece seat bracket . It had some scratches on it and I could see some rust specs under the paint. It turned out good.
The stack was blasted + painted with 2000 degree header paint, and a pipe made from aluminized automotive exhaust pipe I have here last week and put on today. The 16HP air cleaner cover was also blasted + painted last week and put on today.
The headlamp housing was checked out with a good used lens, I didn't want to touch the NOS lens for this as they pretty much don't exist, except for here that is... It got new springs, contacts, and lead out wires put in it along with the 51LED per bulb I use. They are crazy bright and don't run hot like the original bulbs do. The whole setup was tested on the bench then put on the hood to make sure everything lined up, all is good there I just need to wire them up.
Last edit: 08 Sep 2026 18:41 by Geno.
08 Sep 2026 19:13 - 08 Sep 2026 19:15 #19138
This is post #2 for today.
The NOS shift knobs are on and decals are on. It has a NOS hood latch knob, new factory felt pieces on the dash top, and polished 403 stainless acorn nuts and washers on the new hood latch assy. Some of the felt is exposed which is because the front of the hood is slightly bent forward. I'll see if I can deal with that but it's not likely to move because of where the bends are. I will still give it a try when my help gets back tomorrow.
The steering shaft cover called for a WH 107687. I had 4 of them in the back NOS, another part that doesn't exist when I searched. They would be fine for someone that just had one missing or damaged but I don't think they're good enough for this tractor as it will be easily seen. The cuts are terrible and not square as you can see with one chucked up in the lathe. By the time I get it cleaned up and perfect it will be a little short... I decided I'm going to make one from an Acetal Copolymer rod, it is a type of very hard plastic and the rods are black as well. The rod is as strong as aluminum and easy to machine on the lathe. I'll get pics of it as I make it later.
I have also done one thing I thought was impossible. I had a super nice original steering wheel here on my steering parts pallet rack I found last week. I've been digging everywhere for one over the past few weeks. It is dyed and sitting on the tractor, I just need to make the new shaft cover then it can be mounted.
It's past leaving time, more to come later.
Last edit: 08 Sep 2026 19:15 by Geno.
09 Sep 2026 10:55 #19139
WOW...Great Job
